How to create baseline on graph
  • darko11z
    • Jun 2022
    • 23
    on Zabbix 6.0 I am creating a new graph.
    - Add widget.
    - Select type: Graph
    - Type in host name and select measure item.
    I get bellow graph.
    On this same graph I would like to have baseline - just straight line (if possible dashed):
    How to add baseline to particular graph?
    Regards
    That widget has no such option... You can have some additional item with the value (calculated item with just required value as "calculation") and add it to graph... Sounds lame... yes...
    • darko11z
      • Jun 2022
      • 23
      I don't have admin rights on Zabbix server. I am just a user with rights on Zabbix that can add widgets.
      Where exactly is "calculated item" added? Any details are appreciated or pointing to some documentation.
        Without any admin rights, you cannot add items unfortunately. But you could add it to same template, where your items are...
