Hi
I'm trying to resolve a monitoring design problem with an elegant solution, and I'm not finding the features I was hoping for.
In a nutshell, I'd like to only run specific low level discoveries IF an snmp item (in a different snmp branch) returns a specific value.
Let me provide a couple of example scenarios:
- I'd like to monitor the status of switch stack interfaces only if the switch has stack configured (my switches report stack ports offline even if stack is not configured).
- I'd like to monitor router's licences, but different versions present licence info on a different OIDs.
For both, at the moment, I have to create an additional template which only contains the specific LLD, and add it to the device.
Is there a way around that? I looked at "overrides" in the LLD configuration and they seem to serve a different purpose.
Using different templates or linked templates makes keeping them updated very hard, so I am hoping to be able to avoid it.
If this cannot be done in the LLD, is there a way to apply a template automatically based on host tags? I could populate tags using a discovery + override if it's possible.
Thanks!
Stefano
Thanks!
Stefano
