I have some questions on the zabbix agent on Linux and hope anyone can help me.
I have setup the agent on a Redhat ES3 server and have zabbix agent running. I am trying to monitor the CPU loading and so I looked at the system.cpu.load as well as the system.cpu.util.
1. I got the some data on the cpu load, but don't know how to interrupt. Most of the time the value is about 0.2-0.3 and the max value is just around 0.5. Any idea on the actual loading? What is the max value of the load?
2. I also looked at the cpu util, and the percentage is switching in a range of several percent, say 1-5. However, I use top to check the loading and the CPU is can reach about 30-40%. If the cpu util is an average load, is it possible to set the average of a shorter time period, say 5-10 seconds?
