Zabbix overview matrix
  • cskopataki
    • Sep 2016
    I need to monitor several countries databases and I want to use the overview tab in Zabbix.
    I want to create this overview
    Country 1 Country 2 Country 3 Country 4 Country 5
    Trigger 1
    Trigger 2
    Trigger 3
    The main problem is that all of the countries are configured to the same host, and I couldn't configure a trigger which e.g monitoring the active SID's in the databases and send warning in Trigger 1 row in that country where the issue is occur.
    If I configure host's for all countries than I'll need to configure triggers for each countries and it will looks like this
    e.g
    ----------------------Country TH-----Country HK---Country PH
    Trigger SID TH-----------X
    Trigger SID HK-----------------------------X
    Trigger SID PH-------------------------------------------X
    Does anyone have any idea how to solve this?
    -------------------------Country 1------Country 2---Country 3---Country 4
    Trigger SID ---------------X--------------X
    Trigger jobs broken----------------------------------X---------------X
    Trigger 3
    Thanks in advance,
    Regards
