Webcheck scenario step number in trigger message
  • arr1val
    • Nov 2023
    Greetings.
    I have easy webscenario with multiple steps that check subdomains for code 200 and some required strings on page.
    Trigger expression:
    length(last(/example.com/web.test.error[WWW2check]))>0 and last(/example/web.test.fail[WWW2check])<>0
    Trigger name:
    {HOST.NAME} - failed: {ITEM.VALUE}
    Also read https://support.zabbix.com/browse/ZBXNEXT-209 that STEP name unavailable.
    Now i have:
    Problem: example.com - failed: response code "502" did not match any of the required status codes "200"
    Will be more usefull:
    Problem: example.com - failed at step #: response code "502" did not match any of the required status codes "200"
    Please advise how to do this.
