Zabbix Maps
  • Mun
    • Sep 2016
    • 67
    Zabbix Maps
    Can anyone help me with this issue?
    Case 1:
    1. I create a map with a sharing type >> public (user A should be able to view as it public)
    2. Under the above map, I create one submap with a sharing type >> private
    Case 2:
    1. I create a map with a sharing type >> private & read only permission for user A
    For both cases, when I logged in as A, I'm not able to view the map & the submap as well. The idea is to let A, view the map but not the submap.
    Thank You.
  • pc-nico
    • May 2014
    • 29
    today i had the same problemen...
    MAP 1 is public, all use can see it in the past
    yesterday i create 3 Submaps für MAP 1... they are by default privat....
    Today all user can´t see MAP 1... after i mark all 3 Submap as public all user can see MAP 1...
    not a solution for your problem, but it is reproducible understandable
    PS: This happens even in deeper levels....
    like
    MAP 1
    -> SubMap 1.1
    -> SubMap 1.1.1 -> e.g. Privat -> User can not see MAP 1
    -> SubMap 1.1.2
    -> SubMap 1.2
