When I try to check HTTP status, it returns 1 (running) with below configuration settings.
1. Type >> Simple Check
2. Key >> net.tcp.service.perf[http]
But then, when i'm trying to check the HTTP Performance with below configuration:
2. Key >> net.tcp.service.perf[http,,80]
There is no value for the above item. Is there anyone having the same issue?
Thanks.
Thanks.
