error with mssql integration
  • df@rackhosting.com
    • Jan 2024
    I get this error when i try to use the mssql integration with a mssql server.
    Preprocessing failed for: [{"object_name":"MSSQL$SQLEXPRESS:Access Methods","counter_name":"AU cleanup batches/sec","instan...
    1. Failed: cannot extract value from json by path "$[?(@.object_name=='SQLServer:Locks' && @.counter_name=='Average Wait Time Base' && @.instance_name=='_Total')].cntr_value.first()": no data matches the specified path​
    the zabbix can connect without issue with isql command
