How to monitor external k8s cluster?
  • elgoch0
    • Jan 2024
    I'm trying to monitor k8s cluster A from my Zabbix instance (installed in k8s cluster Z), I followed the steps indicated at https://www.zabbix.com/integrations/kubernetes and setting values for:
    - {$KUBE.API.URL} = https://$IP_OR_DNSNAME_OF_A_CONTROL_PLANE:6443/api
    - {$KUBE.STATE.ENDPOINT.NAME} = zabbix-agent-kube-state-metrics
    - {$KUBE.API.TOKEN} --> obtained doing:
    kubectl -n zabbix get secret -o jsonpath={.data.token} zabbix-service-account | base64 -d
    for the hosts created to set the templates Kubernetes cluster state by HTTP​ and Kubernetes nodes by HTTP​
    but I get this error:
    250:20240124:172134.576 [ Kubernetes ] ERROR: Request failed with status code 403: {"kind
    ":"Status","apiVersion":"v1","metadata":{},"status ":"Failure","message":"v1 \"nodes\" is for
    bidden: User \"system:serviceaccount:zabbix:zabbix-service-account\" cannot get resource \"v
    1\" in API group \"\" at the cluster scope","reason":"Forbidden","details":{"name":"nodes","
    kind":"v1"},"code":403}
    I know TOKEN is right because:
    $ curl -X GET https://$IP_OR_DNSNAME_OF_A_CONTROL_PLANE:6443/api --header "Authorization: Bearer $TOKEN" --insecure
    "kind": "APIVersions",
    "versions": [
    "v1"
    "serverAddressByClientCIDRs": [
    "clientCIDR": "0.0.0.0/0",
    "serverAddress": "$IP:6443"
    but
    curl -X GET https://$IP_OR_DNSNAME_OF_A_CONTROL_PLANE:6443/endpoints --header "Authorization: Bearer $TOKEN" --insecure
    "kind": "Status",
    "apiVersion": "v1",
    "metadata": {},
    "status": "Failure",
    "message": "forbidden: User \"system:serviceaccount:zabbix:zabbix-service-account
    \" cannot get path \"/endpoints\"",
    "reason": "Forbidden",
    "details": {},
    "code": 403
    My guess is some missing grants in service account system:serviceaccount:zabbix:zabbix-service-account, but even if I tried to grant admin permissions I got the same result
    Any idea what am I missing here?
    Thanks!
  • elgoch0
    • Jan 2024
    I made some progress, Cluster node monitoring using the template "Kubernetes nodes by HTTP" is working now, the fix was basically:
    1. Zabbix Agent2 v6.4.6 (I tried v6.4.10 but it did some weird things with the monitoring of the databases)
    2. Set macros
    - {$KUBE.API.TOKEN}
    - {$KUBE.API.URL} --> should be similar to:
    https://$CP_NODE:6443
    - {$KUBE.NODES.ENDPOINT.NAME} --> get the value using:
    kubectl -n $ZABBIX_AGENT_NAMESPACE get ep
    (use the one that looks like "zabbix-agent-zabbix-helm-chrt-agent")
    but ​Main cluster components monitoring using the template "Kubernetes cluster state by HTTP" is still not working, very likely because endpoint:
    ​zabbix-agent-kube-state-metrics 10.42.6.179:8080
    is not reachable from outside the cluster (a proxy might be my way to go in this case)​
