iDrac RACADM read nicstatistics?
  • Knuppel
    • Jan 2024
    I have 2 Dell Hyper-V hosts, one being replication destination / standby in case of failure. These servers are connected to an out-of-band network via iDrac. They are powered via 2 UPSes both connected to a seperate outlet.
    Now, when the power fails on both outlets, the UPSes send an SMTP trap to my out-of-band server. I want it to then immideately shutdown the standby Hyper-V host, to preserve power. But ONLY if it is not running Hyper-V guests. To not just wire my production and out-of-band network together, i've found a way to 'signal' my iDrac that there are no Hyper-V guests running. Namely through the onboard NIC's. A Powershell script does a check every 5 minutes, no guests running = NIC port 4 disabled.
    Unfortunately, info about the onboard NIC is not represented in SNMP. I can however read this via RACADM cli tool. Is there any way to have Zabbix use this tool?
