Which function for "Too Many Login Attempts"
  • BigSmooth
    • Jun 2023
    • 46
    I am gathering windows event logs for my application and filter on a pattern like "Unsuccessful login attempts".
    With a preprocessing, the item stores a list of failed attemps. Item value is the login name.
    2024-01-30 15:07:50 user1
    2024-01-30 15:03:50 user2
    2024-01-30 15:02:50 user1
    2024-01-30 14:58:50 user1
    2024-01-30 14:34:50 user1
    2024-01-30 14:28:50 user1
    What would be the formular to do a count of failed login attempt for each logins and raise a trigger when it is above 3 on a 15 minutes period?
    It is some kind of aggregation, but based on item value and not item name.
    Regards,
    Olivier
  • nathanvandalen
    • Jan 2023
    • 11
    Think the best way is to use the count() history function
    4 History functions (zabbix.com)​​
    Examples:
    count(/host/key,10m,"like","error") #the number of values for the last 10 minutes until now that contain 'error'​
    • BigSmooth
      • Jun 2023
      • 46
      If I am not wrong, it will not be counted per login name, will it?
      I don't want to raise an alarm if 10 users made a mistake, but if 1 user made 3 login attempts.
        • 4993
        Then you need trigger per user... I cannot think of any function, that would take any possible value and count them in time... Trigger function is dumb in that sense... if you do not tell it, what to look for, ie. what username, then it does not know it...
        • BigSmooth
          • Jun 2023
          • 46
          I was looking for something like (if you are familiar with sql):
          select username, count(*) from failed_login group by username;
