Network Interface Op Status
  • kenw@auvilfruit.com
    • Jan 2024
    I am new to Zabbix and I have a question about the Operational Status of a network switch interface. The value returned is either a 1 or 2 and that shows up in the graph. I am wondering if it is possible to change the display to show Up for 1 and Down for 2? Hope this makes sense.
    • 4993
    One way is to use value mappings. https://www.zabbix.com/documentation.../items/mapping
      • Jan 2024
      Cyber, thank you for the information. I really appreciate it. When I am setting up my dashboard, the status shows as up or down as long as I select Item Value as the type. If I try to put it in a graph, the Y axis only shows the numerical value, 1 or 2. Is this by design?
        • 4993
        I guess, yes... value mapping does not replace axis values... Maybe I was too eager to suggest things... those might not work everywhere.
