the table "dbversion" was not found.
  • msohani
    • Jan 2024
    Dear All,
    i just faced with this error
    Unable to determine current Zabbix database version: the table "dbversion" was not foundrelated snapshot attached, i searched about this error many times and do necessary actions but nothings changed
    please check this log too :
    /var/log/mysql# vi error.log
    2024-01-31T05:58:17.156787Z 4 [System] [MY-013381] [Server] Server upgrade from '80035' to '80036' started.
    2024-01-31T05:58:22.287610Z 4 [System] [MY-013381] [Server] Server upgrade from '80035' to '80036' completed.
    2024-01-31T05:58:22.423500Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
    2024-01-31T05:58:22.423554Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
    2024-01-31T05:58:22.425024Z 0 [Warning] [MY-011810] [Server] Insecure configuration for --pid-file: Location '/tmp' in the path is accessible to all OS users. Consider choosing a different directory.
    2024-01-31T05:58:22.450340Z 0 [System] [MY-010931] [Server] /usr/sbin/mysqld: ready for connections. Version: '8.0.36-0ubuntu0.20.04.1' socket: '/tmp/tmp.pdWAnCxkjX/mysqld.sock' port: 0 (Ubuntu).
    2024-01-31T05:58:22.450322Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Socket: /var/run/mysqld/mysqlx.sock
    2024-01-31T05:58:22.494377Z 0 [System] [MY-013172] [Server] Received SHUTDOWN from user <via user signal>. Shutting down mysqld (Version: 8.0.36-0ubuntu0.20.04.1).
    2024-01-31T05:58:24.566285Z 0 [System] [MY-010910] [Server] /usr/sbin/mysqld: Shutdown complete (mysqld 8.0.36-0ubuntu0.20.04.1) (Ubuntu).
    2024-01-31T05:58:25.049657Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.36-0ubuntu0.20.04.1) starting as process 149775
    2024-01-31T05:58:25.062035Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
    2024-01-31T05:58:25.300050Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
    2024-01-31T05:58:25.523207Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
    2024-01-31T05:58:25.523263Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
    2024-01-31T05:58:25.524951Z 0 [Warning] [MY-011810] [Server] Insecure configuration for --pid-file: Location '/tmp' in the path is accessible to all OS users. Consider choosing a different directory.
    2024-01-31T05:58:25.558495Z 7 [System] [MY-013172] [Server] Received SHUTDOWN from user boot. Shutting down mysqld (Version: 8.0.36-0ubuntu0.20.04.1).
    2024-01-31T05:58:25.559688Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Bind-address: '127.0.0.1' port: 33060, socket: /var/run/mysqld/mysqlx.sock
    2024-01-31T05:58:27.292748Z 0 [System] [MY-010910] [Server] /usr/sbin/mysqld: Shutdown complete (mysqld 8.0.36-0ubuntu0.20.04.1) (Ubuntu).
    2024-01-31T05:58:29.092379Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.36-0ubuntu0.20.04.1) starting as process 149924
    2024-01-31T05:58:29.102069Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
    2024-01-31T05:58:29.332667Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
    2024-01-31T05:58:29.601692Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
    2024-01-31T05:58:29.601781Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
    2024-01-31T05:58:29.633539Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Bind-address: '127.0.0.1' port: 33060, socket: /var/run/mysqld/mysqlx.sock
    2024-01-31T05:58:29.633627Z 0 [System] [MY-010931] [Server] /usr/sbin/mysqld: ready for connections. Version: '8.0.36-0ubuntu0.20.04.1' socket: '/var/run/mysqld/mysqld.sock' port: 3306 (Ubuntu).
    Zabbix server Version :
    zabbix_server --version
    zabbix_server (Zabbix) 6.4.11
    Mysql version :
    Your MySQL connection id is 21
    Server version: 8.0.36-0ubuntu0.20.04.1 (Ubuntu)
    my sql databases :
    mysql> show databases;
    | Database |
    | information_schema |
    | mysql |
    | performance_schema |
    | sys |
    | zabbix |
    5 rows in set (0.00 sec)
    mysql> use zabbix;
    Database changed
    mysql> show tables;
    | Tables_in_zabbix |
    | applications |
    | dchecks |
    | drules |
    | group_discovery |
    | group_prototype |
    | hosts |
    | hstgrp |
    | httpstep |
    | httptest |
    | interface |
    | items |
    | maintenances |
    | screen_user |
    | screen_usrgrp |
    | screens |
    | screens_items |
    | slides |
    | slideshow_user |
    | slideshow_usrgrp |
    | slideshows |
    | users |
    | valuemaps |
    i don't know what to do anymore
    • 4993
    Your log snippet is from mysql log, seems you upgraded it and it works now...
    The table list looks very short for what it needs to be .. I think there should be 100+ tables
    If this is a new installation, you probably need to recreate your DB schema, as it is clearly bad... And then try again connecting to it.
    If it was a working Zabbix instance before... you backup maybe handy at this point... but there are better mysql people around here, than I am ...
