Hi everyone,
I'm trying to have a action that turns ON and OFF, 2 HVAC systems every 24h to rotate between units.
For the unit 1 I have the following trigger conditions:
Time period in 1-1,00:00-24:00;3-3,00:00-24:00;5-5,00:00-24:00;7-7,00:00-24:00
Trigger doesn't equal "Temperature high"
Trigger equals "Unit 1 is OFF"
Trigger doesn't equal "Failed communications with unit 1"
Trigger doesn't equal "Unit 1 has errors"
Trigger doesn't equal "Failed communications with unit 2"
Trigger doesn't equal "Unit 2 has errors"
Actions: (Step duration 5m)
Step 1 -> Send command "Turn ON Unit 1" (sent after 1m)
Step 2 -> Send command "Turn OFF Unit 2" (sent after 1m)
For the Unit 2 I have the following trigger conditions:
Time period in 2-2,00:00-24:00;4-4,00:00-24:00;6-6,00:00-24:00
Trigger equals "Unit 2 is OFF"
Step 1 -> Send command "Turn ON Unit 2" (sent after 1m)
Step 2 -> Send command "Turn OFF Unit 1" (sent after 1m)
Calculation is and for all the trigger conditions: 1 and (2 and 3 and 4 and 5 and 6 and 7)
These actions aren't working as intended, meaning when 24h pass and the conditions are met for either action the commands aren't sent. Only when I force turn OFF/ON the units do these actions work.
What am I missing?
thank you advance.
