Disk Space alerting on <90 with VSI's having filesystems with /dev/loop at 100%
  • rbelsch
    • Apr 2023
    I have been trying to remediate a trigger for disk space <90.
    This isn't an issue on any of our Baremetal servers but VSI's have a dev/loop* filesystem that cause the trigger to go off constantly.
    the current trigger expression is:
    last(Template-OS-Linux-VPN/vfs.fs.size[/,pfree])<90
    discovery uses the Linux by Zabbix agent and gets moved to the above template.
    On the Linux by Zabbix Agent template I have added to the discovery rule for Mounted filesystem discover the following:
    Filter: {#FSNAME} matches @File systems for discovery exclude
    under admin -> general - regular expressions I have:
    expressions -
    Results are FALSE ^(/loop)$
    the filesystems in question are:
    /dev/loop0 64M 64M 0 100% /snap/core20/2015
    /dev/loop1 64M 64M 0 100% /snap/core20/2105
    /dev/loop2 92M 92M 0 100% /snap/lxd/24061
    /dev/loop4 41M 41M 0 100% /snap/snapd/20290
    /dev/loop5 41M 41M 0 100% /snap/snapd/20671​
    I'm not sure if the expression should be on /snap or the loop?
    • 4993
    it is a regex you need there... not exact match.
    ^(/loop)$ will match /loop and nothing more. But to your question... assuming you use either vfs.fs.get or vfs.fs.discvoery to get all FS-es... those use "Mounted on" not "Filesystem" for items... So matching for /loop will not work. You should probably try to exclude ^(/snap/.*)$
