LLD based on result 'create / run' other LLD rule
  • Brambo
    • Jul 2023
    • 256
    Need a bit of help to figure out the following.
    I have an already fine running LLD rule which creates the correct items and value.
    However I notice that the system which is providing this data also have additonal pages with details.
    The links to those pages are part of the original json output.
    I can gather those URLs with the LLD however here comes the tricky part, the additional details are on a different page.
    Original data is on http://<ip>:8800, and the statuspage returns: http://hostname:8801 or 8799 etc the numbers are in range of the original but could be higher or lower.
    Removing the hostname part and only gather port isn't the challenge, regex
    :\S.*:(\S*.)
    But I can't figure out how to do the following:
    Create an http agent item to gather the specific page AND then use a 'new' LLD rule to create items from that page
  • Answer selected by Brambo at 01-02-2024, 13:07.
    dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Looks like you want to vote for https://support.zabbix.com/browse/ZBXNEXT-1527 ?
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      • Brambo
        • Jul 2023
        • 256
        dimir Looks like it.
        For now I'm exploring a work around but need to transform some values and then see if it could work
