How to integrate cisco meraki with zabbix?
  • omer.meister
    • Jan 2024
    Hello there,
    I've looked all over the internet in order to find one solution which works since the official documentation is incomplete. I have created a meraki api token on my portal, also created a host item for the organization in zabbix, applied the built in "meraki organization" template, applied the token in the matching macro field and nothing happend. the api url is the default "api.meraki.com/api/v1" . The zabbix server external address is also allowed on the meraki portal. Zabbix version is 6.4. I havn't configured any Interfaces on the host items since no guide mentioned them.
    The vpn and network errors items shows "Failed to parse response received from Meraki API. Check debug log for more information." also enabling Debug and going through the whole page debug didn't produce anything helpful.
    I will kindly thank anyone who can instruct me where is this log located (got nothing relevant on the "/var/log/Zabbixzabbix_agentd.log" log)
    Of course if someone has a working configuration this will be the best
    zabbix_server.log might be more relevant.
