Move system to AWS RDS, get rid of timescaledb
  • StormScorpion
    • Feb 2024
    • 22
    I want to move our current Zabbix Installation to AWS (ECS / RDS). Today we use timescaledb, which is not supported by RDS.
    Is it possible to transfer all data without history? I tried with pg_dump and pg_restore and skipped the timescaledb tables. But there were a lot of references to the timescaledb tables, so Zabbix did not start.
    Or is it possible to re convert history from timescaledb to plain postgres tables?
  • Answer selected by StormScorpion at 29-02-2024, 07:44.
    StormScorpion
    • Feb 2024
    • 22
    I managed to migrate the data, cyber thanks for pointing me at the right direction. Here the steps used in case this is helpful to someone else.
    Dump database without history/trends tables
    pg_dump -T history* -T trend* -N *timescaledb* -f zabbix.dump -d zabbix_prod_db
    Edit dump with vi and remove two timescaledb lines at the beginning
    Export history/trends as CSV
    psql -c "\COPY (SELECT * FROM history_log) TO history_log.dump.csv DELIMITER ',' CSV" zabbix_prod_db
    psql -c "\COPY (SELECT * FROM history_str) TO history_str.dump.csv DELIMITER ',' CSV" zabbix_prod_db
    psql -c "\COPY (SELECT * FROM history_text) TO history_text.dump.csv DELIMITER ',' CSV" zabbix_prod_db
    psql -c "\COPY (SELECT * FROM history_uint) TO history_uint.dump.csv DELIMITER ',' CSV" zabbix_prod_db
    psql -c "\COPY (SELECT * FROM history) TO history.dump.csv DELIMITER ',' CSV" zabbix_prod_db
    psql -c "\COPY (SELECT * FROM trends_uint) TO trends_uint.dump.csv DELIMITER ',' CSV" zabbix_prod_db
    psql -c "\COPY (SELECT * FROM trends) TO trends.dump.csv DELIMITER ',' CSV" zabbix_prod_db​
    Compress and transfer to target system
    createdb zabbix
    createuser zabbix
    Create history/trends Tables from sql script in install dir
    Import data
    psql -f zabbix_prod_db.dump zabbix
    Import history/trends
    psql -d zabbix -c "\COPY history_log from history_log.dump.csv CSV"
    psql -d zabbix -c "\COPY history_str from history_str.dump.csv CSV"
    psql -d zabbix -c "\COPY history_text from history_text.dump.csv CSV"
    psql -d zabbix -c "\COPY history_uint from history_uint.dump.csv CSV"
    psql -d zabbix -c "\COPY history from history.dump.csv CSV"
    psql -d zabbix -c "\COPY trends_uint from trends_uint.dump.csv CSV"
    psql -d zabbix -c "\COPY trends from trends.dump.csv CSV"​
    Alter housekeeping
    UPDATE config SET db_extension='',hk_history_global=0,hk_trends_glob al=0;
    UPDATE config SET compression_status=0,compress_older='7d';​
    Importing CSV data took 3 hours for 25GB data. You could drop primary keys on the tables to speed up this process. Dont forget to create them later :-)
    • Brambo
      • Jul 2023
      • 256
      I can't help you with the actual problem.
      However if you would post the command's used to export your data and how you did try to import I expect people to be more helpful to point you in the right direction.
        Export data to CSV and import from it... (replace ${table} as needed. It will take time ...
        psql -c "\COPY (SELECT * FROM ${table}) TO ${table}.dump.csv DELIMITER ',' CSV" zabbix
        later import
        psql -d zabbix -c "\COPY ${table} FROM $(table}.dump.csv CSV"​
        • StormScorpion
          • Feb 2024
          • 22
          createdb zabbix
          createuser zabbix
          Import data
          Alter housekeeping
