Zabbix when running as container, config datasource in grafana
  • JaniL
    • Nov 2023
    We are running zabbix in k8s, we have 4 services 1:server, 1roxy 1:web 1:webservice
    Everything is working fine
    But we want to conf zabbix as a datasource in grafana, unfortunately there is not much documantation about it when its running in containers.
    Has anyone tried it and got that to work?
    what could be the url to create this datasource in grafana
  • PeterZielony
    • Nov 2022
    • 146
    http(s)://<zabbix_frontend>/api_jsonrpc.php
    full documentation here:
    Use the Zabbix data source to visualize monitoring data from Zabbix in Grafana dashboards.
    Hiring in the UK? Drop a message
    • JaniL
      • Nov 2023
      So the service ip of the web (frontend) should work in this case
        Yes, that plugin works mainly through API. There is option to use direct DB calls, but it is not recommended option.
