Zabbix prometheus integration
  • Pitros
    • Feb 2024
    Hi! I'm having issues with Prometheus, Node exporter and zabbix integration. The metrics site of node exporter is reachable just fine from my terminal but zabbix pops up an error message Cannot perform request: Couldn't connect to server. Any ideas?
    Just in case asking... "your terminal" means zabbix server command line?
    selinux configured?
    If you want to determine whether zabbix can connect to all TCP ports, you must turn on the zabbix_can_network boolean. Disabled by default.
    setsebool -P zabbix_can_network 1
    • Pitros
      • Feb 2024
      Hi cyber, terminal was the CLI of linux.
      I've managed to make my selinux permissive which fixed the issue.
      Thanks for the answer!
