Ask about features
  • Ahmed99
    • Feb 2024
    Ask about features
    I'm interested in the Zabbix solution. I understand that the solution provides supervision for web applications. I wanted to know if the Zabbix solution offers supervision for the following elements:
    1. Hardware (examples: processor, memory, local storage, power consumption, network)
    2. Software installed on the workstation (examples: loading time, errors, CPU and memory usage)
    3. For the Office suite, a more detailed view (opening time for emails, waiting time for sending, opening time for encrypted emails, opening time for the calendar, opening time for Teams, display time for Teams, etc.)
    4. Operating System (examples: crashes, blue screens, driver issues)
    5. Antivirus, EDR (examples: impact of the process on equipment load)
    6. Filers (examples: network drives, OneDrive)
    7. Equipment startup (Example: including details up to the end of session loading as well as user-initiated shutdowns "button")
    Thank you!
  • PeterZielony
    • Nov 2022
    • 146
    1) - yes - they are default templates to do it
    2-7 ) not outside the box - Zabbix is very flexible but it will require a lot of custom work and setting custom templates including but not limited to scripting etc.
    I suggest starting with documentation and seeing what it can do. This will give you an overview of the functionality it offers
    You would also need to make sure the data you require is available to be queried (using any methods like API, logs, powershell, bash etc etc.). Zabbix can query anything you like - as long data is accessible in any form
    for example:
    3. For the Office suite, a more detailed view opening time for emails, waiting time for sending, opening time for encrypted emails, opening time for the calendar, opening time for Teams, display time for Teams, etc.
    is available somewhere as a metric or logs? - meaning if you know how to query this per instance then it is possible - otherwise no.
    Zabbix is a tool for querying available data - but data needs to be available to be queried in 1st place.
    rest it just configure it in a way so you can gather data and structure it
    Hiring in the UK? Drop a message
    • Ahmed99
      • Feb 2024
      Thank you for your response. I am currently thoroughly reading the official documentation. I have another question: Is there a system for pushing information and gathering user feedback? such as through via pop-up or toast notifications integrated into the agent, to launch targeted user feedback campaigns or to perform push notifications in the event of an application incident for specific user profiles?
        No. There is no such thing.
