Multi-Node Upgrade
  • nyjetfan
    • Sep 2016
    Multi-Node Upgrade
    Hi all - I have inherited a 3 node zabbix install which I believe is a Server, UI and a database server. I'm being asked to upgrade this from 3.0 to 3.2 and wanted to see if anyone has ever done something similar that can provide some insight/input? Not sure if they have to be updated in a specific order or how much reconfiguration will be required after they are updated. Please advise if you can shed any light on this topic. Thanks so much!
    Here's the yum list installed output (filtered to just zabbix):
    HOST A
    zabbix-agent.x86_64 3.0.4-1.el7 @zabbix
    zabbix-release.noarch 3.0-1.el7 installed
    zabbix-server-mysql.x86_64 3.0.4-1.el7 @zabbix
    HOST B
    zabbix-web.noarch 3.0.4-1.el7 @zabbix
    zabbix-web-mysql.noarch 3.0.4-1.el7 @zabbix
    HOST C
    zabbix-agent.x86_64 3.0.3-1.el7 @zabbix
    zabbix-server-mysql.x86_64 3.0.3-1.el7 @zabbix
