Re-discovering devices / manual discovery
  • LarsB
    • Feb 2024
    New to Zabbix, looking to move from Librenms.
    The setup is a web server, proxy sevrr and a db-server running PostGreSQL.
    I have created a discovery for a subnet, and the devices did get discovered - but I wanted to make a change to the discovery, adding location OID as Visual Name.
    Am I right to understand that there is NO way for me to do a re-discovery manually?
    I tried to delete the discovery rule, and add it again - but to no avail, discovery did not restart.
    How to I get the devices re-discovered?!
    You mean that your hosts did not change name after you changed discovery rule? There is one line in docs (https://www.zabbix.com/documentation...work_discovery)... "If the host name has been set using an item value, it is not updated during the following discovery checks." I think you need to remove that host for it to be rediscovered..
    • LarsB
      • Feb 2024
      Exactly, hosts did not change their visible names when the discover rule was changed to use another OID for visible name.
      After digging through a lot of documentation and random google hits, I came up short - and just deleted all the hosts (140 Cisco switches), but the discovery rule was set to run at an 8 hour interval, and the hosts was only re-discovered after the 8 hours.
      Changing interval to 5 minutes did nothing, as there can be no overlapping afaik, and even with the hosts deleted, the discovery did not run at the new interval but after the initial 8 hours!​
