Problems with creating a map
  • tazzu
    • Nov 2006
    • 26
    Hi Guys,
    i just installed zabbix an i wonder how big the funktionally is. First i am sorry for my bad english but i hope you can understand me
    I have some Problems by building a map. When i try to add an element so i cant choose any icons. By this is an mandatory field i cant create any element. On different faq i see that the guys selectet icons with names like "router" "firewall" or something else... I cant choose any of this icons. My select box i completly clear.
    My second question is how i can build my own background. Where must i place the picture and what format i have to choose?
    I hope someone here can help me
    Regards
    Tazzu
  • Calimero
    • Nov 2006
    • 481
    When loading the database schema/default data, did you load zabbix-<version>/create/data/images.sql into your database ?
    Configuration > General then choose Images in the dropdown list. You can upload new images.
    Images are stored in blob fields in "Images" table.
    • tazzu
      • Nov 2006
      • 26
      I think so !
      when i try to load again i get
      zabbix@linux:~/zabbix/create/mysql> mysql -u root -p zabbix < schema.sql
      Enter password:
      ERROR 1050 at line 25: Table 'services' already exists
      • Calimero
        • Nov 2006
        • 481
        When installing, you have to load/execute three SQL scripts (script names here are for mysql):
        - create/data/data.sql
        - create/data/images.sql
        - create/mysql/schema.sql
        Did you load all three ?
        • tazzu
          • Nov 2006
          • 26
          I forget to load create/data/images.sql in my database
          Thank you Calimero
          • Calimero
            • Nov 2006
            • 481
            You've already loaded the script once. If you really want to restart from scratch drop all the tables (or even drop the database and recreate it).
