Temperature Thresholds
  • eric859
    • Dec 2023
    • 13
    I just added my brocade switches to Zabbix. I immediately started getting temperature warnings. They thresholds being used by Zabbix are a little low. I'd like to up them to the documented thresholds. We have 3 different switch models, each with different temp thresholds, so changing the Macro in the "Brocade_Foundry Stackable by SNMP" template is not enough. I need to put 3 separate thresholds for the 3 models. How do I go about changing the config to say if <model> = 7250, then use this threshold... If <model> = 7450, then use this threshold...If <model> = 7750, then use this threshold...?
    The idea that first comes to mind is to copy the "Brocade_Foundry Stackable by SNMP" template 2 more times - 1 for each model -, change the thresholds and reassign the 3 templates to the 3 different models. Is this the best way of accomplishing this?
    Thanks!
  • Hamardaban
    • May 2019
    • 2714
    take a look at https://www.zabbix.com/documentation...macros_context or https://www.zabbix.com/documentation...overy#override
