Discovery Rule for VPN Interface
  • steveck
    • Feb 2024
    I'm new to Zabbix and the forums,
    I have a template that I use for cellular routers and it has a discovery rule to capture any and all IP addresses on any and all of the interfaces on each one of the routers. The issue I'm running into is that the items that are generated for each of the IP addresses on the router are dynamic and follow the interface's index number. What I would like to do is have static items for the each of the IP addresses discovered using the discovery rule. How could I go about setting that up using discovery rules?
    Thanks in advance!
