Invalid parameter authtype when importing
  • wiliamL
    • Feb 2022
    • 28
    Moving templates from a system that went from 6.1 to 6.4 to a new system and getting
    • Invalid parameter "/59/authtype": value must be 0.
    How do i find out what template it is and why am i getting this error?
    any help is always appreciated.
    ~Wil
  • azyla
    • Feb 2024
    • 20
    This issue looks similar to the one discussed in this topic. Also you might want to have a look at ZBX-22669. Error message might not be identical, however the solution may be suitable as well.
    Hope it helps.
    Regards,
    Arkadiusz
