Zabbix 7. Have applications been removed from hosts and templates?
  • anonamoose
    • May 2019
    • 16
    Is this something that is permanently removed? Or will it be added in towards the end of the testing? We're on Zabbix 5, so I don't know what's changed in the interim. We're also feeding a ton of data into a Grafana server using the Zabbix API and every graph relies on filters for an application. What is the solution to this? If applications have been removed does a newer version of Grafana Zabbix API take this into account? I noticed when I was trying to export/import Templates from the old server to the new. Pretty much all my graphs in Grafana will be broken.
    Thanks.
  • Answer selected by anonamoose at 15-02-2024, 22:11.
    cyber
    • 4985
    Applications were replaced with tags already in v6. You probably need to rework your graphs based on tags.. But that plugin knows how to use tags...
      • 4985
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        Applications were removed completely in 5.4.0 and replaced with "tags": https://www.zabbix.com/documentation...d-applications
        • anonamoose
          • May 2019
          • 16
          Okay, thanks guys. What I will do is build a brand new grafana server in conjunction with the new zabbix server since we're migrating off Centos 7 to Rocky Linux 9. That way I can work out all the kinks before moving both into production and retiring the old servers. Our Grafana is quite out of date as well.
          I appreciate the feedback.
