vfs.dir.size correct trigger
  • hkjarral
    • Jul 2019
    • 9
    I setup vfs.dir.size to monitor directory and generate alert when directory size if greater than 5GB but Its still generating alerts even for size less than 5GB. Please see snapshot. What am I missing ?
  • hkjarral
    • Jul 2019
    • 9
    Nevermind I figured the correct size should in bytes not GB. hence trigger should be generated when value is greater than 5,368,709,120 Bytes
