at first we use another frontend for configuring zabbix monitoring entries, so if I use expressions that don't relate to the exact item/description in zabbix please forgive me.
I would like to get some insight into:
Filesystem INODE
I am aware of the fact, that the number of remaining inodes can get to zero , while still having enough space on the disk/partition.
Is the alarm sounded /email sent , when the number of used inodes exceeds a certain percentage on any given partition / mountpoint?
Filesystem SIZE
while I used 'Filesystem SIZE PUSED' by determining the mountpoint ; and this works as expected, in 'Filesystem SIZE' there is no mountpoint setting.
And it is not clear to which measures the threshold setting relates to.
Greetings Amadeus
Filesystem INODE
Filesystem SIZE
Greetings Amadeus
