OSPF Trigger
  • xtianfab
    • Aug 2023
    • 15
    OSPF Trigger
    I am trying to configure triggers for the state of OSPF sessions, but the problem I am having is that the OID does not exist when the port goes down, so the current state value cannot be obtained.
    If I use the last trigger, it does not work because of what was mentioned above, the OID no longer exists.
    I also tried nodata, but with this trigger alerts are generated even though the data is being brought.
    Would you have any idea how I can generate alerts for the OSPf states?​
