Create Trigger
  • koki098
    • Feb 2024
    Create Trigger
    Hello, I am using the 'Template Net Cisco IOS SNMP' for a Cisco switch, which includes the 'outbound packets discarded' item for each interface but lacks a trigger. How can I create a trigger for it?
  • azyla
    • Feb 2024
    • 20
    Go to Configuration (or Data Collection if Zabbix version 6.4) -> Templates -> click on the Template name (or select Triggers hyperlink in the same row and omit next step) -> click on Triggers hyperlink at the top of the screen -> click on Create trigger button in the top right corner. You should enter the Trigger creation form, if you need some more information on how to proceed with the creation process itself, refer to the official Zabbix documentation: 3 Triggers (zabbix.com) and search through the subtopics visible on the left side menu.
    Hope it helps.
    Regards.
    Arkadiusz​
