Simple concatenate - Lost
  • jdoggy31
    • Feb 2019
    • 39
    Hello I have a template that has a few Items that I need to concatenate together - This seams simple but I just can make it work. It looks like I need a calculated item that uses the function concat. Any help would be a life saver.
    Template Name: Concat-Test
    Iteam 1 Key: TestKey1
    Itean 2 Key: TestKey2
  • Hamardaban
    • May 2019
    • 2714
    concat(last(\Concat-Test\TestKey1),last(\Concat-Test\TestKey2))
    • jdoggy31
      • Feb 2019
      • 39
      Thank you - when i try this i get
      Details Cannot update item
      • Invalid parameter "/1/params": incorrect expression starting from "concat(last(\Concat-Test\TestKey1),last(\Concat-Test\TestKey2))".
      Zabbix Ver 6.4.7
      • Hamardaban
        • May 2019
        • 2714
        Im sorry.... "concat(last(/Concat-Test/TestKey1),last(/Concat-Test/TestKey2))"
        or try "concat(last(//TestKey1),last(//TestKey2))"
        Please refer to the documentation for the correct syntax. Everyone makes mistakes.... :-(
        • jdoggy31
          • Feb 2019
          • 39
          Well - I cant tell you how many times i referred the docs and completely missed it. it was indeed that I was \ when i should be /. THANK YOU!!!
