.htaccess file do not work
  • NormanW
    • Feb 2024
    Dear members,
    I've tried to protect my Zabbix Web page with an Login before the Zabbix login web page is coming up, with a .htaccess file in the directory: /usr/share/zabbix (where the index.php is)
    the content of that .htaccess is:
    cat .htaccess
    # .htaccess-Datei für Passwortschutz
    AuthType Basic
    AuthName "Geschützter Bereich - Bitte geben Sie ein Passwort ein!"
    AuthUserFile /opt/.htpasswd
    Require valid-user
    However, it seems that .htaccess will not be recognized.
    Therefore I've changed the /etc/zabbix/apache.conf file: (as well in /etc/apache2/sites-enabled/zabbix.conf)
    <Directory "/usr/share/zabbix">
    Options FollowSymLinks
    AllowOverride Options <= changed None to Options, however also ALL didn't work
    Order allow,deny
    Allow from all​
    I use apache2 2.4.57-2
    My system:
    OS: Debian GNU/Linux 12 (bookworm) x86_64
    Kernel: 6.5.0-0.deb12.1-amd64
    Shell: zsh 5.9
    Memory: 3587MiB / 7844MiB
    GPU Driver: i915
    CPU Usage: 43%
    Disk (/): 213G / 915G (25%)
    The reason is: I have several web servers subdirectories, and just one IP. So I would like to protect the access to each of the other subdirectories.
    That .htaccess works fine for the pihole /admin subdiretory
    is there any area where I have not looked?
    Thank you all in advanced.
    Norman
  • solution
    • Jun 2020
    • 272
    remove the .htaccess and try this:
    apache/conf-enable/zabbix.conf
    AllowOverride All
    Order allow,deny
    Allow from all
    AuthType Basic
    AuthName "Restricted Access"
    AuthUserFile /opt/.filename
    Require valid-user
    Restart Apache
    Wellington
    • NormanW
      • Feb 2024
      Brilliant. Your solution works fine. I was not sure if this works in the zabbix.conf file directly.
      Many Thanks.
