Kubernetes PVC Available Space left monitoring
  • andreasbe
    • Feb 2024
    tl;dr
    Is it possible to monitor used space on k8s pvc's with zabbix already?
    I managed to setup zabbix k8s monitoring using the helm chart.
    I was wondering if anyone already setup persistent volume claims monitoring as done visually by this grafana dashboard
    It uses among others this prometheus metric to get the available bytes
    kubelet_volume_stats_available_bytes
    Zabbix Template Kubernetes cluster state by HTTP Kubernetes: Get state metrics: PVC discovery or any other template does not seem to make use of pvc metrics which include available bytes
    Do you know of any template which offers pvc used space discovery?
    Otherwise I'll try my best to adopt it myself (Not much experience in Zabbix templates, though)
    Best regards from Germany
    Andreas
  • jbee43
    • Jun 2024
    Did you manage to figure this out?
    I'm struggling to adapt the Get state metrics: PV discovery rule in Kubernetes cluster state by HTTP template as well
    I see the keys, the scripts, but can't find or understand the mapping apparently
    Also, for some reason, while everything else works great, the Controller manager and Scheduler are retrieving nothing, but the endpoints seem to be fine
    • mahesh396
      • Mar 2024
      jbee43 In my case i have updated the {$KUBE.STATE.ENDPOINT.NAME} macro to get it worked.
      But it just discovers PV and PVC status and not getting available space left
      • andreasbe
        • Feb 2024
        Yes by switching to prometheus / grafana / alert manager for this task
        We love zabbix, but k8s support was not satisfying / we could not spend enough time to get it running properly.
        (Sorry I did not receive a notification about new answers, although I was subscribed all the time)
        • NgRox
          • Jun 2022
          • 45
          It is necessary to create a custom monitoring setup by exposing port 10250, which is the Kubelet port (it comes installed on every cluster node).
          You need to create a token and run a query to retrieve the used space of PVCs:
          You can get this token by running:
          TOKEN=$(kubectl get secret <token-name> -n <namespace> -o jsonpath="{.data.token}" | base64 -d)
          Exec:
          curl -k -H "Authorization: Bearer $TOKEN" https://<ip>:10250/metrics
          This will return values like:
          kubelet_volume_stats_used_bytes{namespace="default ",persistentvolumeclaim="myclaim3"} 1.91054843904e+11
          kubelet_volume_stats_used_bytes{namespace="default ",persistentvolumeclaim="myclaim4"} 1.91027953664e+11
          kubelet_volume_stats_used_bytes{namespace="default ",persistentvolumeclaim="myclaim5"} 1.91019491328e+11
          From this data, you can configure a calculated item to subtract used from total space to determine the free space.
