The login page is not loaded
  • cobra-arbok
    • May 2021
    I'm new to Zabbix which I installed on my small server.
    Upon installation I received an error.
    Zabbix_server.log reported that MySQL version 80300 is not supported, but this was already present because it was installed with a previous application.
    I therefore reported AllowUnsupportedDBVersions=1 in the Zabbix server configuration file.
    Now with http://IP-Server/zabbix nothing appears.
    Is there anything I can still do?
    When will a version of Zabbix be available that will support this version of MySQL?
  • solution
    • Jun 2020
    • 272
    What version did you install?
    Zabbix Server 6.4 already supports it.
    Frontend/GUI
    For Apache: http://ip-server/zabbix
    For NGINX: http://ip-server/
    Wellington​
    • cobra-arbok
      • May 2021
      $ zabbix_server --version
      zabbix_server (Zabbix) 6.4.11
      Revision fb6439a26e3 29 January 2024, compilation time: Jan 29 2024 10:54:38
      But with http://ip-server/zabbix I always have ERR_CONNECTION_TIMED_OUT.
      If MySQL is supported, why are there these errors?
        5237:20240226:191753.942 ******************************
        5237:20240226:191753.942 using configuration file: /etc/zabbix/zabbix_server.conf
        5237:20240226:191753.985 Unsupported DB! MySQL version 80300 is newer than maximum allowed 80299
        5237:20240226:191753.985 Warning! Unsupported MySQL database version (8.03.00).
        5237:20240226:191753.985 Should not be higher than (8.02.x).
        5237:20240226:191753.985 Use of supported database version is highly recommended.
        5237:20240226:191753.996 current database version (mandatory/optional): 06040000/06040026
        5237:20240226:191753.996 required mandatory version: 06040000
      with systemctl status
      zabbix-server, zabbix-agent and apache 2 are running.
      How can I check what went wrong with the installation?
      I put a comment in front of AllowUnsupportedDBVersions=1 and restarted zabbix_server, but the page is still unreachable
      • TcoUpLoad
        • Dec 2022
        • 29
        Update to zabbix 6.4.12 because they added the support
        ZBXNEXT-8984 Updated max supported MySQL version to 8.3
        • solution
          • Jun 2020
          • 272
          6.4.11... this explains the Mysql Version warning
          Do what TcoUpLoad said:
          apt upgrade or yum/dnf upgrade
          Frontend/GUI
          Have you already installed it?
          to install
          dnf install zabbix-web-mysql zabbix-apache-conf
          systemctl restart httpd
          or
          apt install zabbix-frontend-php zabbix-apache-conf
          systemctl restart apache2​
          If you have an active firewall, open port 80
          http://ip-server/zabbix​
          Wellington
          • cobra-arbok
            • May 2021
            OK, now I'm working.
            Thanks to everyone
