Zabbix does not filter out records
  • zvictorp
    • Feb 2024
    Dear community
    The discovery rule looks as follows
    discovery[{#EXTIFNAME},1.3.6.1.4.1.3715.17.3.1.1.2,{#EXTIFMO DULE},1.3.6.1.4.1.3715.17.3.1.1.3,{#EXTIFPHYINTERF ACE},1.3.6.1.4.1.3715.17.3.1.1.4,{#EXTIFLOGINTERFA CE},1.3.6.1.4.1.3715.17.3.1.1.5]
    The device responds correctly and Zabbix turns it into right JSON format. That is ok.
    "{#EXTIFLOGINTERFACE}": "254",
    "{#EXTIFMODULE}": "2",
    "{#EXTIFNAME}": "Module 2, IP input interface 1.254",
    "{#EXTIFPHYINTERFACE}": "1",
    "{#SNMPINDEX}": "21010254"
    "{#EXTIFLOGINTERFACE}": "1",
    "{#EXTIFNAME}": "Module 2, Video output interface 1.1",
    "{#SNMPINDEX}": "22010001"
    My goal is to exclude interfaces containing 'input' in its name from the result,
    For this purpose I've created a macros:
    {$EXTIFNAME_NOT_MATCHES} = ^.input.*$
    and added the following filter rule:
    {#EXTIFNAME} does not match {$EXTIFNAME_NOT_MATCHES}​
    However, the filter does not work and always get the same set of values.
    Please, give me a hint where I am wrong.
    Thank you
  • Answer selected by zvictorp at 26-02-2024, 16:35.
    zvictorp
    • Feb 2024
    Thank you for your reply
    Originally posted by cyber
    Your regex does not match your data you can try with "^.*input.*$" or even plain "input" works better that yours.. Yours expects just one character between start of line and "input"...
    I didn’t notice a typo in my post until after I wrote it.
    I didn't know that filters are not applied when Test button pressed. I should create item prototypes and then test results.
      • zvictorp
        • Feb 2024
