Zabbix Server - Missing zabbix_sender
  • slpefanis
    • Jan 2020
    • 52
    Hi All
    I'm looking to automate soem functionality and am trying to use zabbix_sender on my server.
    username@zabbix:/usr/bin$ zabbix_sender
    Command 'zabbix_sender' not found, but can be installed with:
    sudo apt install zabbix-agent
    But when I run the install
    username@zabbix:/usr/bin$ sudo apt install zabbix-agent
    [sudo] password for username:
    Reading package lists... Done
    Building dependency tree... Done
    Reading state information... Done
    zabbix-agent is already the newest version (1:6.4.6-1+ubuntu20.04).
    I'm not sure why it's not available. Any thoughts?
  • solution
    • Jun 2020
    • 272
    Have you installed it?
    try:
    apt install zabbix-sender
    wellington
    • slpefanis
      • Jan 2020
      • 52
      Tried that with no luck unfortunately.
      Package zabbix-sender is a virtual package provided by:
        zabbix-agent 1:5.0.17+dfsg-1 [Not candidate version]
      E: Package 'zabbix-sender' has no installation candidate
      • solution
        • Jun 2020
        • 272
        Install Zabbix 6.4 repo
        Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
        Example for Ubuntu 20 x64
        # wget https://repo.zabbix.com/zabbix/6.4/ubuntu/pool/main/z/zabbix-release/zabbix-release_6.4-1+ubuntu20.04_all.deb
        # dpkg -i zabbix-release_6.4-1+ubuntu20.04_all.deb
        # apt update
        And then try installing again:
        Wellington
        • slpefanis
          • Jan 2020
          • 52
          No love sorry, I'm not sure why it's beeing so difficult for something that should be so easy?
          username@zabbix:/var/log$ sudo wget https://repo.zabbix.com/zabbix/6.4/ubuntu/pool/main/z/zabbix-release/zabbix-release_6.4-1+ubuntu20.04_all.deb
          --2024-03-03 14:07:53--  https://repo.zabbix.com/zabbix/6.4/ubuntu/pool/main/z/zabbix-release/zabbix-release_6.4-1+ubuntu20.04_all.deb
          Resolving repo.zabbix.com (repo.zabbix.com)... 178.128.6.101, 2604:a880:2:d0::2062:d001
          Connecting to repo.zabbix.com (repo.zabbix.com)|178.128.6.101|:443... connected.
          HTTP request sent, awaiting response... 200 OK
          Length: 3752 (3.7K) [application/octet-stream]
          Saving to: ‘zabbix-release_6.4-1+ubuntu20.04_all.deb’
          zabbix-release_6.4-1+ub 100%[============================>]   3.66K  --.-KB/s    in 0s
          2024-03-03 14:07:53 (1.29 GB/s) - ‘zabbix-release_6.4-1+ubuntu20.04_all.deb’ saved [3752/3752]
          username@zabbix:/var/log$ sudo dpkg -i zabbix-release_6.4-1+ubuntu20.04_all.deb
          (Reading database ... 142079 files and directories currently installed.)
          Preparing to unpack zabbix-release_6.4-1+ubuntu20.04_all.deb ...
          Unpacking zabbix-release (1:6.4-1+ubuntu20.04) over (1:6.4-1+ubuntu20.04) ...
          Setting up zabbix-release (1:6.4-1+ubuntu20.04) ...
          username@zabbix:/var/log$ sudo apt update
          Hit:1 http://azure.archive.ubuntu.com/ubuntu jammy InRelease
          Get:2 http://azure.archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
          Hit:3 http://azure.archive.ubuntu.com/ubuntu jammy-backports InRelease
          Get:4 http://azure.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [1,421 kB]
          Get:5 https://packages.microsoft.com/ubuntu/22.04/prod jammy InRelease [3,631 B]
          Get:6 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
          Fetched 1,653 kB in 2s (854 kB/s)
          57 packages can be upgraded. Run 'apt list --upgradable' to see them.
          username@zabbix:/var/log$ sudo apt install zabbix-sender
          • solution
            • Jun 2020
            • 272
            Your first post shows "zabbix...ubuntu20.."
            But your last post shows "azure...jammy" that is Ubuntu 22
            Be careful, use the repo compatible with your system.
            Ubuntu 22:
            https://www.zabbix.com/download?zabb...ubuntu&os_vers ion=22.04&components=server_frontend_agent&db=mysq l&ws=apache
            If necessary, remove and reinstall the zabbix packages.
            Wellington
            • slpefanis
              • Jan 2020
              • 52
              Thanks, I done an upgrade to try and resolve this one. I'm running 22.04
              • slpefanis
                • Jan 2020
                • 52
                I ran an upgrade of the zabbix_agent package and it seems to be working now. Thanks for all your help.
