notification without internet connection
  • paul92
    • Oct 2016
    hello guys, im new in this forum and just trying to run zabbix how i need it....
    i just made my server send me email notification and it works perfect!
    now i need an notification when my system lose any connection...
    i think there could be an sms option with an gsm modem...
    maybe i could get an sms when the internet connection is gone.. or something like that :/
    thanks for any help
  • peatb
    • Aug 2016
    • 36
    What you could do is get a gsm modem and have that sent out an sms.
    To set this up you need a trigger that checks the network connection and an action that fires if this trigger fires. The sms mediatype is build in (administration -> mediatypes), you just have to setup the correct device (on our system that's the default /dev/ttyS0).
    Finally, configure the mediatype for each user that needs to receive the sms.
    Alternatively you can have a script that manages the sms sending and make a mediatype calling that script.
    • paul92
      • Oct 2016
      okay thanks i will try it
      does it work with an umts surf stick?
      • Colttt
        • Mar 2009
        • 878
        yes if the stick is supported by linux
        Debian-User
        Sorry for my bad english
        • burn1024
          • Jun 2012
          • 52
          if you have a public ip, an easier option is to monitor that ip by an external service like statuscake
