Web Page Monitor: Trigger configuration
  • alessandro.ranieri
    • Mar 2024
    Dear all,
    new to zabbix and to the forum as well, so nice to vMeet all of you.
    I'm trying to configure a trigger to monitor a specific test web page. Basically I'd like to see if the system can trigger a failure of the web page and one the issue is fixed I'd like to have the probel solved automatically. In order to achive this I configured the followings for my custom trigger:
    Problem expression: last(/DEDHTVEAAMONE.corp.loc/web.test.error[VeeamONE Status],#5)<>0
    Recovery expression​: last(/DEDHTVEAAMONE.corp.loc/web.test.error[VeeamONE Status],#5)=0
    Trigger is able to detetct a page failure, but is not able to clear the error when the page back to normal status.
    Thanks in advance for your help and suggestion.
    BR
    A.
    last(/host/item,#5) .. what does it mean? it is not "five latest values"... it is "fifth latest value" ... So your current trigger will fire if 5th error message from last is not "0"... and would recover if 5th is "0" (and would not require recovery expression at all) .. but I doubt you have error messages like "0" Maybe you want to use web.test.fail item ?
      • Mar 2024
      https://www.zabbix.com/documentation...web.test.error
      HI cyber,
      many thanks for your comment. I will have a look at the documentation and try to adjust my config as suggested.
      BR
      A.
        • Mar 2024
        Originally posted by alessandro.ranieri
        HI cyber,
        BR
        A.
        Hi Cyber, succesfully setup my alert. Thanks for your help.
