remove /zabbix path from apache
  • X4V1
    • Mar 2024
    • 9
    I'm new to Zabbix and I just did the setup (Apache)
    I have a reverse proxy and a domain name and I would like to remove the /zabbix path from the url to access the web interface.
    I would like to be able to reach Zabbix with a direct url like: zabbix.mydomain.com instead of zabbix.mydomain.com/zabbix.
    Could you please help me to find the correct way to do that ? Is it possible directly from the UI ? Or should I change the apache config ? Any idea what must be changed in order to do that ?
    I already searched on the forum and I found multiple threads that are not working anymore (quite old threads).
    I tried to edit "DocumentRoot" from /etc/apache2/sites-available/000-default.conf
    DocumentRoot /var/www/html => DocumentRoot /usr/share/zabbix
    It seems ok at first sight but I think I might have broke something. Could you please tell me if it's a correct way to do it of if it will break other things ?
  • X4V1
    • Mar 2024
    • 9
    It's running since yesterday, everything seems to work fine I'll see if it stays like that
    • lbm
      • Feb 2020
      • 37
      As long as the rest is in place/loaded, like aliases and stuff, I really see no issues.
      And I guess this is the most easy way, if you havent antyhing else running, you would like to default to.
      • irontmp
        • Sep 2023
        • 98
        To remove the /zabbix path from the URL and access Zabbix directly via zabbix.mydomain.com, follow these steps:
        1. Edit Apache Config: Open your Apache virtual host configuration file.
          bash
          Copy code
          sudo nano /etc/apache2/sites-available/000-default.conf
        2. Update DocumentRoot: Change DocumentRoot to point directly to Zabbix.
          apache
          Copy code
          <VirtualHost *:80> ServerName zabbix.mydomain.com DocumentRoot /usr/share/zabbix <Directory "/usr/share/zabbix"> Options FollowSymLinks AllowOverride None Require all granted </Directory> ErrorLog ${APACHE_LOG_DIR}/zabbix_error.log CustomLog ${APACHE_LOG_DIR}/zabbix_access.log combined </VirtualHost>
        3. Restart Apache:
          bash
          Copy code
          sudo systemctl restart apache2
        Now, Zabbix will be accessible via zabbix.mydomain.com without /zabbix.
