FortiADC monitoring over snmp
  • cezve
    • Mar 2024
    I want to monitor FortiADC (Fortinet Advanced Application Delivery Controller) appliance with snmp. But I couldn't find fortiadc tamplate file. After I try to make my own template with mib2zabbix script (https://sbcode.net/zabbix/mib-to-zabbix-template/)
    But I didn't work. The zabbix status column says "Not Supported" under the items page.
    So is there anybody connect zabbix with fortiadc over snmp before?
    Forget that mib2zabbix... it may have worked in the past, but has not been updated for years. Template formats have been changed over time.
    Have you tried, if something is working for you from this template https://www.zabbix.com/integrations/...fortigate_snmp Might not be exactly your device, but might give you some general metrics and you can go on from there by adding your own stuff.
