Template Fortigate by HTTP : Stop working with a port different from 443
  • Funkokedama
    • Mar 2024
    Hi, i'm using template fortigate by http to monitor a Fortigate600E.
    Everything works fine with default port 443.
    I'd like to change default port from 443 to 9443.
    FortigateSide: System-> Settings-> HTTPS port -> 9443
    ZabbixSide: {$FGATE.API.PORT} macro defined at host level in Zabbix -> 9443
    This didn't work.
    From Centos ( zabbix server ) i can reach the port -> nc -z -v x.x.x.x 9443
    Additionally:
    I can't snif any packet produced by Zabbix server with port 9443
    I can snif the packet produced by Centos (Zabbix's server) with this command -> nc -z -v x.x.x.x 9443
  • Answer selected by Funkokedama at 07-03-2024, 12:37.
    cyber
    • 4957
    selinux enabled? By default zabbix server/proxy can connect only to "known ports" like 22 or 443... If you want to enable connecting to any port, you may need to set following
    setsebool -P zabbix_can_network 1
    • Funkokedama
      Funkokedama commented
      You are a genius!
      It worked!
      Thank you so much!
  • markfree
    • Apr 2019
    • 874
    Are you using an HTTP proxy for your Forti ( {$FGATE.HTTP.PROXY} macro )?
    Is your Forti monitored by the Zabbix Server itself or by a Zabbix Proxy?
    Have you configured a trusted host on the FortiGate side?
    Is there a drop rule for port 9443 in your Forti?
    • Funkokedama
      No HTTP proxy; Forti is monitored by Zabbix server.
      Yes trusted host is configured.
      No drop rule configured; also checked local-in policy and how they change when moving https port from 443 to 9443. -> Everything seems ok
      I think that the key point is why i can't snif any packet when changing port from 443 to 9443
    • 4957
    • Funkokedama
      You are a genius!
      It worked!
      Thank you so much!
    • 4957
    No geniuses here... This question has been asked many times already... And I have answered it many times... Someone should take up constructing a FAQ page here... it would certainly be there... along with "how to exclude windows services from discovery" or why my "last(/host/item, #5) trigger expression does not work etc..:P
