is it possible to show issue on graphs
  • HeadQuaker
    • Jul 2015
    • 58
    We have plenty of graph with icmppingsec.
    I would like to know if it was possible to show in color when there is no value like a lost of ping?
  • Answer selected by HeadQuaker at 07-03-2024, 10:17.
    HeadQuaker
    • Jul 2015
    • 58
    EDIT : ok if i remove the content of the Problem field, it's ok.
    • Hamardaban
      • May 2019
      • 2714
      You can display the problem (trigger state) on the graph.
      Ifyou have a trigger set up for the condition you need, turn on its display.
      • HeadQuaker
        • Jul 2015
        • 58
        https://www.zabbix.com/documentation...graph#problems
        ok that what I saw but the graph shows nothing. The trigger is in state problem but nothing on the graph.
        I've checked the checkbox on the graph and selected the host.
        • HeadQuaker
          • Jul 2015
          • 58
