Recovery expression issue
  • itskol@procentris.com
    • Mar 2024
    hi,
    I have problem expression Problem: {host:logrt["C:\ProgramData\Key Metric Software\SQL Backup Master\logs\.*.xml",succeeded].abschange()}=1
    this is working fine when my application getting success message.
    Now I want this notification to resolve after 10 or 15 minits automatically. Then what will be recovery expression ?
    Thanks in advance.
    There is no recovery expression for this... Recovery expression is ADDITIONAL expression that has to become true AFTER trigger expression has already become false... Based on your usage of "abschange" if you receive same value again, it will close (as there is no change)...
    If you add "and {host:logrt["C:\ProgramData\Key Metric Software\SQL Backup Master\logs\.*.xml",succeeded].nodata(10m)}=0" to trigger expression (I hope I still remember old trigger format..) . It will close the problem 10m after last incoming data. ​
      • Mar 2024
      worked like a charm. thanks
