Web Monitoring - save Variable in Step 1 and use it in Step 2
  • kajaaj
    • Mar 2024
    I am trying to monitor a webpage in two steps. In Step 1 I have to save a generated token and in Step 2 I have to use this token to log in to website.
    I am trying to do as is written here: https://www.zabbix.com/documentation...toring/example --> with regex:name="csrf-token" content="([0-9a-z]{16})"
    But the problem is, that in the Step 1 I only have an empty page with string which I have to save in variable, so I can not use - regex: name="" content="" - as is stated above.
    How can I save this string in variable to use it in Step 2?
    Click image for larger version  Name:	grafik.png Views:	23 Size:	7.0 KB ID:	480371
  • Answer selected by kajaaj at 12-03-2024, 16:08.
    kajaaj
    • Mar 2024
    Found the solution:
    regex: (.+) worked for me
    • kajaaj
      • Mar 2024
      Found the solution:
