Hi Zabbix community,
i have Zabbix agent 6.4.0 installed on windows server 2019 and every couple of hours the following error comes up : Receiving an error Zabbix 111 connection refused?
and the service is stopped.
I have found an error log in windows event viewer and found the following :
Faulting application name: zabbix_agentd.exe, version: 6.4.0.2400, timestamp: 0x64072d9e Faulting module name: ntdll.dll, version: 10.0.17763.5458, time stamp: 0xfb111856 Exception code: 0xc0000374 Fault offset: 0x00000000000fb209 Faulting process id: 0x8fc Faulting application start time: 0x01da74778b042692 Faulting application path: C:\Program Files\Zabbix Agent\zabbix_agentd.exe Faulting module path: C:\Windows\SYSTEM32\ntdll.dll Report Id: 65fe3f66-070d-4fd3-b189-a15be8d53f77 Faulting package full name: Faulting package-relative application ID:
what is the meaning of the error as i dont understand what is the problem regarding this issue?
noting that Zabbix server and the server 2019 which needed to be monitored are all in the same subnet also the FW of the windows server is turned off.
Thank you
Thank you
