TCP successful, cannot establish TLS to [[nginxProxy]:10050]...
  • Zabbix_Julian
    • Jul 2022
    • 25
    Hello all, I created a trigger action which should run a batch file: If I stop the service to test if it works, I get the failed status: Get value from agent failed: TCP successful, cannot establish TLS to [[nginxProxy]:10050]: SSL_connect() I/O error: [0] Success. I have the follwing configured:
    ITem:
    Trigger:
    Script for Trigger action:
    Everything else is working. I also executed MSSQL Scripts and receive the Data.
    PSK is also configured correctly.
    Thank you!!
  • Zabbix_Julian
    • Jul 2022
    • 25
    One Additional information. This is a device in a different Network, to monitor it, I've set up a nginx proxy with stream to receive the agent active checks. Everything is working accept the trigger action.
