Remove Unneeded Interfaces
  • stevefxp
    • Aug 2020
    • 168
    Hello all,
    I have some servers that have NICs that are not used and I don't want to report on them. What is the best way to either remove or just not report on them?
    Thanks,
    Steve
    Modify discovery, so they wont be picket up...
    • stevefxp
      • Aug 2020
      • 168
      Discovery under Monitoring?
        Probably in platform monitoring template you have there... windows or linux, you did not specify...
        • stevefxp
          • Aug 2020
          • 168
          It's the Linux agent template I am using. So just go into the template and edit the discovery for interface
            Yea, that sounds like a correct place..
