Problem Widget - Filter Multiple Problems
  • NightEdition
    • Mar 2024
    • 19
    Is it possible to view multiple defined "problems" using the problem widget.
    I understand I can enter a string and any problems that match this string will be shown.
    However if I have multiple problems that don't have a common searchable text string is there a way to show these? (i.e. "memory usage is too high" OR "sever rebooted")
    I've tried regular expressions however this doesn't appear to work.
    I understand I could also tag such problems and filter based on the tag however I would ideally like to filter based on multiple problem names.
  • Answer selected by NightEdition at 29-04-2024, 16:11.
    cyber
    Unfortunately it only accepts a string for comparison. If thee is no common string in those messages, then you are out of luck... either use tags or reconfigure problem names to contain something similar...
    https://www.zabbix.com/documentation...dgets/problems
    Problem You can limit the number of problems displayed by their name. If you enter a string here, only those problems whose name contains the entered string will be displayed. Macros are not expanded.
